Fusion Support
.STL export no longer works
2 REPLIES 2
mick26730
75 Views, 2 Replies
Hello, I use fusion 360 for personal purposes to draw and then print the parts with my 3D printer. I select the part to convert, I choose: export, then the .STL format and I save it in the folder I chose.
It always worked like this, but now the "task status window opens", the name of my task appears,
but remains unfinished indefinitely.
I don't know what to do, I reset the fusion360 settings, but it doesn't work any better.
I also reset the network settings on my PC under Windows 11 and nothing better either.
Thank you .
2 REPLIES 2
mick26730
in reply to: mick26730
I did some tests, my old 3d drawings can still be converted to STL, but the new ones no longer work.
TrippyLighting
You can select the object (body, or component) in the browser in Fusion 360's viewport, right-click and select save as mesh.
That will  provide you also with more options to control the mesh resolution.
Peter Doering
