STL export failure
anders.habo
Message 1 of 1
STL export failure
anders.habo
Since the last update I have experienced a STL export issue, I can export one file OK but then nothing happens...
I tried to export two STL files, started two days ago and the "Job Status" window opened but did not show any progress. It got a bit strange, I exported a part of the model I had in Fusion to one file called "Body" and another called "Frame".
However, in the "Job status" window a third export appeared with the same name as the Fusion model and immediately stated as "Complete", however without the link "Show file in explorer". The progress bars were empty... Since I was on my way out for the weekend I assumed it was "some network issue" and let the PC stand and wait for 2 days...
Just got home but no further progress.
So I restarted Fusion, got a warning that "data is processed" or similar, disregarded that, opened the model again and asked for the same two exports. I got one OK, but for the second, same as above, a third export appeared as above and "blocked" the second STL-file export.
So I restarted again, same results as above, I could export one file but in the second attempt second, the complete model export appeared, immediately as "complete", no "show in file explorer"  and the export I asked for locked with empty progress bar and... Nothing more...
Have the free version and exported loads of STLs before, I don't think it's me, it appeared after the last update. Is it a new limitation in the free version? A bug? Or, even if I don't think so, me...? 😉
/Anders in Sweden
Replies (0)
