"Save as STL" fails with...
Error: Autodesk Translation Services failed to translate the current document to stl file!
Error: STL Translator failed to export data
Export STL takes a long time (cloud based) then does not deliver to specified folder?
What am I doing wrong?
Thanks Justin
@jfkeating and @Anonymous , can you share your design or attach a f3d file?
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
Sure. Here is one file.
In the German part of the forum had someone find out that it must be a problem with the zero point.
When you remove the dependency and move the object a little bit, the export works. If you move the object back to zero it works, too. The problem startet after the update.
This is the same issue as reported here: STL export or save fails
The export works only if you set the file format to ASCII.
I think there is a bug with the STL translator.
Can you give a link to the discussion in the German forum?
