Announcements
Stitching surfaces distorts the result
hajime2MRG3
hajime2MRG3
Stitching surfaces distorts the result. I guess this is a bug. This is not a rendering problem because Zebra analysis shows the distortion too. I can get around the bug by exporting and importing by STEP file before stitching.
Replies (8)
TheCADWhisperer
I would have done the entire design differently right from the start.
First thing I notice is that your Sketch1 is not symmetrical...
hajime2MRG3
How are symmetry and stitching surfaces related in this case? I have no idea why stitching should distort a surface.
TheCADWhisperer
@hajime2MRG3 wrote:
How are symmetry ...
Was your Design Intent for the geometry to be asymmetrical?
If yes, how did you arrive at the values for those spline handle weights and angles?
TrippyLighting
This could be considered a bug, but the only reason you are encountering this is because you use ineffective surfacing techniques.
jeff_strater
Interestingly, that wrinkle goes away if you round-trip through STEP, even after the stitch
before:
After:
I will run this by the modeling team to see if there is anything interesting here.
Jeff Strater
Engineering Director
TrippyLighting
@jeff_strater I've reported such behavior (STEP export/import fixing stuff) numerous times over the years.
jeff_strater
just following up on this:  The modeling kernel team is looking into this, and has acknowledged that there is a problem here.  It will be a while before any bug fix is available, however, so I would encourage you to work around this as best you can.  Sorry not to have a better answer...
Jeff Strater
TheCADWhisperer
I had a completely different modeling technique in mind, but first the Sketch1 asymmetry question would have to be resolved (the very foundation of the design).
