.step file image does not rotate
vgershma
Observer
vgershma
Observer
Observer
I exported a PCB file from KiCad software as .step file. Then inserted the .step file into my existing Fusion 360 design. I'd like to rotate the .step image or it projection, but neither works. When i right click and select rotate angle, the OK box stays greyed out.
Any suggestions please?
thanks
jhackney1972
Please attach the STEP File.
John Hackney, Retired
vgershma
Observer
Observer
just attached the file. thanks
jhackney1972
I do not see an issue with any type of rotate or move.  I attached my Fusion 360 .F3D file, open it and see if you still see the issue.  If you do not, you are not opening it correctly, if you do, then I would be a suspect of your Fusion 360 installation.
jhackney1972
Sometimes when using the Free Move Type and you select Set Pivot, you forget the Set Pivot icon is a toggle and must be selected again AFTER you select the desired Pivot point.
