I'm trying to export some bodies out to STEP files for a client. I have a multi body component and have exported each body as a STEP file no problem. When i try export the assembly as a single STEP file one of the bodies within the assembly doesn't stay in the correct location in relation to the others bodies. Has anyone else had this issue and have a solution?
If i export the assembly as a stl file all bodies are in the correct location.
Thanks.
