Static Simulation Issue I'm having: "Error: The model could not be translated for simulation."
TitanFox239
TitanFox239
I have successfully run stress simulations on my assembly numerous times in the past, but after a change with a component I've been repeatedly getting simulation failures. The last six failures have all said, "The model could not be translated for simulation." I am unsure why this is suddenly happening. There are no interferences, and I can't find a place that's too small or thin wall for the simulator to function correctly. It will even compute the mesh locally perfectly fine. This is quite a frustrating issue.Capture ii.PNGCapture.PNG
henderh
Hi @TitanFox239,
Are you still encountering the error? I was able to receive results:
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
