Static analysis of a structure with a spring
Dear friends,
I have to turn to the respected community and professionals for help.
At first glance, a completely ordinary task opened up a huge number of questions and controversial points. I could not find any hint in the official documentation and resources for the program. Having spent a huge amount of time looking for such examples, I decided to write to you all the same.
So. The crux of the matter is in the static analysis of a small structure.
Two metal triangular elements are interconnected by a single axis in which rotation takes place. The opposite ends of each element are located on the axes where rotation also occurs. The axes themselves are rigidly fixed in 2 planes and have a degree of freedom along Z. A spring is installed on top between the two triangles. The essence of this analysis is to understand how the spring and each structural element behave when a force is applied vertically to one of the triangles. Contacts in this analysis are set as separated for all bodies except for attaching the spring to the left triangle.
Questions:
1. DOF. Is static analysis possible if only 2 axes are not fully fixed in the structure, and the rest of the bodies have separate contacts in order to rotate relative to each other.
2. Spring. The documentation for the program says that one of the conditions of static analysis is when the deformations and displacements of bodies are insignificant or very small. In this regard, do the deformations of a compressible metal spring fit into the criterion of static analysis or are they already referred to as nonlinear analysis? In Solidworks, by the way, in static analysis the spring is included in the type of boundary conditions. When applying nonlinear analysis (with nonlinear materials) to the spring separately and to the entire structure as a whole, Fusion 360 gives an error and refuses to solve.
3. Results. The animation of the static analysis results looks unlikely. When the actual deformations are turned on, the bodies enter each other.
If anyone has done simulations of structures with springs, as well as similar conditions (DOF, contacts), please share your thoughts.
I'll be very grateful to you.
Thank you in advance.
Sincerely.
Vova
