I'm making a 18650 battery case design and I wanted to use parameters for different S/P numbers. It turns out that when I make a square pattern of circles, the dialog accepts the parameter for quantity (a whole number with no unit) and draws the pattern OK, but immediately reports "Compute Failed". See the screencast (no audio, should be self-explanatory) for the procedure and result.
I'm guessing this is a bug, because it computes and draws everything OK, but still reports a problem + I can't remove the newly drawn circles by simply deleting the pattern like i usually would.
