Fusion Support
Splitting Hole Table
1 REPLY 1
mechanicalVVUA2
98 Views, 1 Reply
I have a part with nearly 200 holes and the hole table is far too long by itself to fit on the sheet. Is there anyway to split the hole table so I can fit this table to the sheet.
1 REPLY 1
If you select the Hole Table, you will see a arrow pop up at the center bottom.  Left mouse click and drag it up to create multiple columns.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
