I have an STL that I want to cut into 43 separate bodies and then export each of them as an STL. I imported the STL, converted it to BRep and now I am trying to figure out how to split the BRep into 43 separate bodies. The problem is the body needs to be split in the areas without intersection so I cannot use the split body tool, any suggestions?
