Split body
Split body
kaltenekkerb
Message 1 of 8
Split body
kaltenekkerb
Is it possible to  split an assembled body into it's original components? Thank you.
Replies (7)
Message 2 of 8
TheCADWhisperer
@kaltenekkerb
Or if it was imported geometry then Attach the original.
Message 3 of 8
kaltenekkerb
I have assembled 3 components and would like to split them. Is that possible with Fusion? Thank yoo.
Message 4 of 8
kaltenekkerb
SDomehow the file got messed up, here is a screeshot.
Message 5 of 8
jhackney1972
If you want to return an assembly back to it’s original components simply select the assembly joints in the timeline and remove them.
John Hackney, Retired
Message 6 of 8
TheCADWhisperer
@kaltenekkerb
See Attached file...
BTW - in you assembly I would expect to see one Grounded Component and at least one Revolute Joint rather than two Rigid Joints.
I see other issues as well.
What exactly are you attempting to model?
Would you like step-by-step instruction on how to do all of this correctly in Fusion 360?
Message 7 of 8
kaltenekkerb
Thank you. I am trying to learn but it is difficult.
Message 8 of 8
TheCADWhisperer
The learning process can be eased by following the instructions of the experts here - but you have to agree on active two-way communication.  I asked you a question that you did not answer.  In a previous discussion thread I asked you 3 questions that you did not answer.
Let’s  try one more time.
Q1. What is your Design Intent - that is, what are you attempting to design?  Do you have any pictures of something similar from the real world?
Q2. Are you willing to follow step-by-step instructions?
