Split Body "unhandled intersecting tool data"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm modeling a door frame and I'm trying to split the body to show how it will be constructed with butt joints. I'm having trouble splitting the body using faces of the body. I do similar operations often with shelled features and recently I've been running into this error more often. The split will fail and give me an "unhandled intersecting tool data" error (see attached). As far as I can tell my selected planes aren't close to intersecting with each other. I've also tried the same operation using one body surface at a time with the same result. I know there are similar forum posts with this error but they all seem like complex splits, while mine are two very well defined and simple parallel splitting planes.
I can get around this error by making construction planes and using them to make the split, but that's three extra steps for something that should only be one. I could also add this split in with my sketch geometry but that also introduces more unnecessary steps to my workflow (multiple extrudes to ensure separate bodies (separate bodies are necessary to show correct construction in drawings and correct orientation of wood grain in renders)). While these solutions work I believe my initial workflow should have worked the first time around.
I've attached a model and relevant screenshots.
