Split bodies joint issue.
eliz
Observer Observer
eliz
Observer
Observer
i have T split a body, when printing in PLA body 1 will not fit/slide into body 2. I'm trying to change the size of the T on body 1 but it will not let me do so. What can I do to make the 2 bodies fit and slide into each other?
Im a noobie so please details so i can follow.
Thank you.
jeff_strater
You need to use Offset Face, either to make the inside of the "female" side bigger, or the outside of the "male" side smaller.  Just select those faces, and offset by some amount.  I'm not sure for PLA what that offset would be, but you should experiment a little to see what fits
Jeff Strater
Engineering Director
davebYYPCU
I use Thin Extrude, select the T outline, and wall thickness is the amount of clearance required.
Might help....
eliz
Observer
Observer
Thank you both ways work. Thin Extrude is easier and faster. Thank you.
