Fusion Support
Spline import
4 REPLIES 4
150 Views, 4 Replies
Spline import
Good day
I am teaching Fusion to myself, but I am struggling. I am trying to import a line (it is the downstream side profile of an ogee spillway) from Excel but I am not successful. The measurements should be in meters (thus the max value is 0.277m) and I need to work on the XZ plane. When I try to import the CSV file, I receive a “No valid points” message. Would you be able to help me? I have attached a screenshot of the software I am using, the shape I need constructed in inventor and the CSV file.
4 REPLIES 4
jeff_strater
in reply to: 23611278
This appears to be a question about Inventor, but this is a Fusion support forum.  Did you mean to put it on the Inventor forum?  https://forums.autodesk.com/t5/inventor-forum/bd-p/78/page/2642?solved-posts-page=9?filter-label=inv...
Jeff Strater
Engineering Director
in reply to: jeff_strater
Good morning. No, it is for fusion. I have managed to import the spline on Inventor, but not on fusion.
jeff_strater
It's because of the conventions used in this CSV.  The decimal is using a "," as a decimal point (European convention), and ";" as a separator.  If I replace the "," with ".", and ";" with ",", it works.  The Import CSV Spline add in in Fusion is limited.  Feel free to copy and enhance it.  Modified file attached
Jeff Strater
HughesTooling
@23611278 Try the import add in from this post by @JeromeBriot Not sure if this is the most up to date version.
Mark Hughes
Owner, Hughes Tooling
