Announcements
spline creating from sketch elements?
ercox
ercox
Is it possible to join existing sketch elements such as arcs and lines into a spline?  I would like to have the inspect command feedback the length of open outline without having to add up the lengths of individual elements.  Inventor had a join and break command, is there something similar?
jhackney1972
There is no Join command in Fusion 360 but you can use the same method I outlined in your other post to find the length of multiple open segments even in multiple sketches as long as they join each other.
John Hackney, Retired
TrippyLighting
Not sure what inventor has, but joining lines and arcs will never result in a spline.
