Spiral/Twist vase
Spiral/Twist vase
Spiral/Twist vase
Hi!
I have created a few spiral/twist vases but I´m also getting the same effect on the inside. So I´m wondering how I can have the effect on only the outside and still have a smooth inside?
HughesTooling
Create as a solid then use a revolve cut for the inside.
Mark
Mark Hughes
Owner, Hughes Tooling
I'm kinda new to fusion 360 so just wondering how I do that in create form cause atm I only know how to do the spiral pattern there.
TrippyLighting
In that case share the model (public link to the design from data panel).
wmhazzard
Here is one way to do it @Anonymous . I swept a profile along a line with a taper and a twist, then on a offset plane I sketched a circle and swept it with the same taper as the outside.
Sorry Trippy I always hit the wrong reply button.
