Announcements
SPICE Simulation - Simulator not found! Please check Simulator Path in Directories dialog.
I can't get the SPICE simulation to work. Trying to start a simulation always returns the error message "Simulator not found! Please check Simulator Path in Directories dialog.".
However, if I look into the directory for simulation ("../ngspice/bin") it does contain the ngspice executables.
How can I fix this?
(I used a fresh installation with just the ngspice-simulation library added)
Best regards
jorge_garcia
Hi @Anonymous,
I hope you're doing well. Just bear with us a little bit, a fix will be out shortly for this.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
kmorris1077
I'm running into this too. Any update on when the fix will go out?
Kevin
jorge_garcia
Hi @kmorris1077 ,
I hope you're doing well. Try making sure Fusion has updated. As far as I know the fix should be in already.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
