Announcements
Spacemouse movement restriction in sketch mode
g-andresen
g-andresen
After the update 2.0.11680, there was a report in the German forum of a limitation of the spacemouse in sketch mode.
There, the action of the spacemouse is limited to PAN & Zoom, whereby rotations are not possible. However, if you move the viewcube minimally, the full range of movement is available again.
I have recreated the behaviour and ask if this is an intended behaviour.
günther
pmeyer2Z7KX
I've have also noticed this.  You can also "break loose" the restriction by rotating with the middle mouse button but it comes back if you click a view (eg. top, side) or start editing a sketch again.  I also had this behavior when I enabled the preview of the 3d connexion options in preferences, so I turned that back off.  Until this latest update when they moved it out of preview.
I'm on Fusion 2.0.11680, and 3dConnexion 10.8.3.3389 (latest as of this morning), Windows 10.
g-andresen
@jeff_strater
Can you say something about this behaviour ?
günther
jeff_strater
see this thread:  problem-auto-lock-rotation-in-sketch-mode
Jeff Strater
Engineering Director
g-andresen
Thank you for the info.
günther
Phil.E
There is an update to Fusion 360 to address the following issues for customers using Windows:
  • Support for older 3Dconnexion devices
  • 3Dconnexion pan and zoom behavior in Sketch mode
The update includes a new preference to use the legacy 3Dconnexion drivers for the experience of the previous integration between Fusion and 3Dconnexion devices. If you have an older device, it should be supported by the Legacy driver setting in Fusion.
Note: This will also remove the newest features like constrained orbit, and advanced button customization features, but only temporarily. We are currently working with 3Dconnexion on a solution for the sketch pan/zoom behavior that is intended to provide both the latest functionality as well as options for sketch behavior.
To get the latest build, 2.0.11894:
  1. Restart Fusion 360
  2. Watch the Job Status indicator
  3. When complete, click Restart Fusion
To get the Legacy driver option:
  1. Open Preferences
  2. Click the dropdown next to SpaceMouse driver
  3. Select Legacy
  4. When prompted, restart Fusion
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Phil.E
3dconnexion has released their latest driver for windows with full support for Sketch Lock on/off. The version is now 10.8.5
Steps:
1. After installing the latest drivers, open the 3dconnexion settings, Advanced, Other:
This will enable supported devices to take advantage of full Fusion 360 command integration/customization, as well has have control to turn on/off the Sketch Lock feature.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
