Hello, where do I get this space between the points I measure and the dimension?
Dimension extension line offsets are set by the application and cannot be modified. That gap is necessary to keep from confusing the extension line from the model edges so it should not be eliminated but in higher CAD packages the offset (gap) can be adjusted, just not Fusion 360, at this time.
John Hackney, Retired
