Announcements
Sorry, Fusion was unable to save sufficient data for Offline mode and needs to go Online. Please make sure you have a working Internet connection to continue
imaduddinsyed09
Message 1 of 10
imaduddinsyed09
I am facing the above error while opening the Fusion 360.
I go through all the steps of troubleshooting on the website. But my error was not resolved. The link of troubleshooting that I follow is :
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Sor...
Please reply to me as soon as possible.
Replies (9)
Message 2 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hey @imaduddinsyed09 ,
Sorry to hear you are experiencing that! Just to check - have you been able to log into Fusion 360 before, on this same network? Are you using a home internet network?
Can you please collect your application log files and post them here
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 10
imaduddinsyed09
Hey @James.Youmatz
After installing Fusion 360, I log into it then I get this error.
And yes, I am using a home internet network.
I attached my application log files in the form of a zip folder.
Message 4 of 10
imaduddinsyed09
The above zip folder is inside "C:\Users\DELL\AppData\Local\Autodesk\Autodesk Fusion 360"
I attach the other two zip folders,
"first_logs" folder is inside -> "C:\Users\DELL\AppData\Local\Autodesk\Autodesk Fusion 360\7HUKQKEW8H87"
and "second_logs" folder is inside -> "C:\Users\DELL\AppData\Local\Autodesk\Autodesk Fusion 360\CFT5M9B5WUF7"
Message 5 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hi @imaduddinsyed09 ,
It looks like some URLs may be having a hard time being reached. From the logs:
20210916T164254 W 1784 Reqest: Call failed: https://js.prd.fusionapi.autodesk.com/fusion360-runtime-config/config.json : WinHttpSendRequest: 12029: A connection with the server could not be established
It states that a connection with the server could not be established. Do you have any anti-virus or network policies that may be prohibiting that URL from being reached?
James Youmatz
Message 6 of 10
imaduddinsyed09
@James.Youmatz, I haven't any anti-virus or network policies.
Message 7 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Interesting. Something is causing that network call to fail - and likely why you see that sign in failure.
What happens when you try to access https://js.prd.fusionapi.autodesk.com/fusion360-runtime-config/config.jsonin a web browser? Does it succeed and show text? Or is it blocked?
Can you successfully access and login to login.autodesk360.com?
Has Fusion 360 ever worked on this computer before?
James Youmatz
Message 8 of 10
imaduddinsyed09
 This URL -> "https://js.prd.fusionapi.autodesk.com/fusion360-runtime-config/config.json"  shows the text and it is not blocked.
Yes, I am successfully access and login to login.autodesk360.com
No, Fusion 360 never worked on this computer before and it shows the above-mentioned errors since I installed it.
Message 9 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Do you have the ability to test on a different network or hotspot? I'm also wondering if resetting your router may do the trick.
James
James Youmatz
Message 10 of 10
imaduddinsyed09
Yeah, I already tested it on three different networks...
