Working on a model that was produced with creo then exported as a step/iges I noticed some wonkiness' with this groove that is supposed to be straight for the 'lead-in' portion of the part after opening it in fusion to start CAM. I assumed it had something to do with the source model or how it was exported until I went back into creo with a colleague and did some investigation. Opening the exported mesh file back into creo showed no such anomalies so I tried to investigate further with fusion. I created a plane where the groove looked the widest to split the model so I could measure the width of the groove at the intersection.
In doing this I noticed that as soon as I split the model, the initial area of the groove 'became' straight?!?!
After seeing that I assume the issue is not with the source file but some kind of rendering tolerance and so I ask you, beloved forums, in hopes of some kind of explanation. ❤️
I would prefer not to post the .F3d file if at all possible, thanks for your help.
Overall view:
<Model before being split, Model after being split>
