Announcements
Solid Sweep
lgadette
Solid Sweep
lgadette
I'd like to sweep a solid cylinder keeping the X-Plane faces parallel to each other throughout the sweep. Any ideas? The new functionality excited me for a moment but it doesn't appear than it can constrain movement relative to a plane.
CADacombs
Do you mean aligned with the Y axis?
Can anyone help?
Starting geometry:
Solid Sweep Perpendicular:
Solid Sweep Parallel:
Solid Sweep Aligned:
lgadette
Aligned to the Y is correct. I see your findings are the same as mine.
rblumen
Observer
Observer
I seem to be encountering the same failure you observe when selecting the "parallel" option, the solid sweep fails to solve.
