Fusion Support
Software continually crashes while trying to sweep a profile.
2 REPLIES 2
louispregler
75 Views, 2 Replies
So I am trying to sweep a profile around the base of this model. No matter what Sketch I try the software just crashes with no explanation or error. I cant even extrude this profile. Same Issue. What is the issue here?
2 REPLIES 2
jhackney1972
in reply to: louispregler
I do not have any issues creating the Sweep you specified.  Model is attached.  If you application cannot perform this task I suggest the best thing to try is to use the Repair option in the Fusion 360 Service Utilities.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
louispregler
in reply to: jhackney1972
For whatever the reason this morning, everything worked as it should. I spent hours last night trying to fix it with no luck.
