Snapping issue...
Snapping issue...
dimka21.2
Observer Observer
Snapping issue...
dimka21.2
Observer
Observer
I've moved sketch from point to point and now i spanning doesn't work...
Screencast: https://youtu.be/Sz4rgTog138
davebYYPCU
Turn Off,
Sketch 1, 3d Sketch, Snap to Grid, and the Grid.
Might help.....
jhackney1972
Please attach your model containing this problem sketch.  Open model, select File menu, then Export and save to your hard drive.  Attach it to your next post.
John Hackney, Retired
dimka21.2
Observer
Observer
done
Sketch 2
jhackney1972
Your sketch was on on the sketch plane.  The Screencast will show this.  By the way, you should begin to fully constrain your sketches to become efficient in the use of Fusion 360.  Model is attached.
jhackney1972
If my solution to your Forum question gave you the information you needed, please select the Accept Solution icon on my post.  If you need further help please ask.
