Announcements
Slot Sketch Entities
craig.baudendistel
craig.baudendistel
So having trouble with sketch slots. Upon creation, I am unable to pick any relevant points on the slot with which to impose constraints. See video. Thoughts?
jeff_strater
Hard to say for certain without the model itself.  But, my guess is that the "circle" is not a circle at all.  because of the draft there, my guess is that this is not a true circle, but is instead a spline curve, which is why it is filtered out for Concentric.  There should, though, be points where the edge seam exists.  I'm not sure if a vertical constraint at that point will give you the design intent you are looking for, but it might.  Another approach would be to project the bottom edge of that shape into the sketch, assuming that is a circle, and that should allow Concentric to be applied.  Again, if we had the model, it would be easier to try a few things.
Jeff Strater
Engineering Director
craig.baudendistel
Bingo! So that initial feature was a loft. Had to check the "Keep Tangent Edges" button. This must convert those edge entities in something usable. Unchecked, it must be a spline. Weird.
Thank you for the push in that direction!
