sliding contact sets and frictionless contraints in simulation environment
Hello team,
I have been having a lot of trouble creating a sliding contact/ constraint for a static stress analysis. In the model below (see screenshot), I want the sample/ beam to move freely over the dowels/ bearings as a load is applied. I have tried making the dowels both pin and frictionless, the samples frictionless and then changing the required contacts to sliding and separation without any luck. I can get the simulation to work when it is all fixed (albeit showing incorrect results) but when I try and put in the sliding fit, it either fails or produces unwanted results like
Any help is much appreciated!!
Trying to select slider contact sets, but the pre-check suggests unconstrained bodies which leads to failed simulations:
When all contact sets are kept as rigid the simulation works (almost as supposed to be), except for the deflection where the beam and the bearing joins
Making the surfaces of the bearings and the beam frictionless leads to an incorrect result:
