Announcements
SKP File like a mesh
louisG8UJ3
louisG8UJ3
hello there everyone,
I took a SKP file from the internet of the AUDI RS6, beauty of a car but it has like a mesh body with a lot of squares.. my problem is how can I fix this? I already tried things like repair or smooth options but it doesn't help at all.. when I try to render it you can also see all the squares.
thanks to someone who answers the forum
jeff_strater
SKP is a mesh format.  So, yes, that type will import as a mesh.  You can control how it is displayed with this setting:
But, that will only change how it is displayed, not the nature of the mesh itself.
What do you plan to do with this model?
Jeff Strater
Engineering Director
TrippyLighting
What exactly needs to be fixed and what do you want to do with the end result ?
Also, this is clearly a triangulated mesh and not a quad mesh. I suspect it started as a quad mesh based on the tooology.
louisG8UJ3
hi there, thank you for your response! the option doesn't work... I can't see any progress on the model. my main target is to render the model
thank you
TrippyLighting
Can you share the file?
louisG8UJ3
sure! I send it
TrippyLighting
This is purely my opinion, but I think you are much better off rendering this in Blender than in Fusion 360.
Blender works natively with Meshes and the render engines in Blender (Eevee and Cycles) are much more powerful than the render engine in Fusion 360.
The time it will take to make this into something useful for Fusion 360 is better spent learning the render engines in Blender. Blender is a very powerful tool in its own right, but it also makes a great companion for the T-Spline modeling in Fusion 360
