Sketching in Fusion is a Joy
TheCADWhisperer
Consultant Consultant
TheCADWhisperer
After 5+ years - I thought we were past this...
Ah, I thought it was a fluke... ...but I just reproduced the issue...
TheCADWhisperer
What's up with this?
Feels like old times (last year)...
Showing fully constrained before even adding the Radius dimension...
jeff_strater
FUS-76689
Jeff Strater
Engineering Director
ampster40
what was the fix?  I am not seeing anything within the reply from Jeff other than "FUS-76689".
jeff_strater
that's the internal Fusion bug number.  There is no fix - you can add the radius dimension, and it will not be a problem - it will not result in an over constrained error.
Jeff Strater
TheCADWhisperer
@jeff_strater wrote:
....you can add the radius dimension, and it will not be a problem ...
Just to be sure - you did see the issues with both examples I found this morning, correct?
Issue 1.  Slot is fully constrained but shown as unconstrained.
Issue2.  Arc shown as constrained but it is not constrained.  (I think you are responding to this issue._
