Announcements
Sketcher broke, and can't revert to previous version
Noah_Katz
Message 1 of 12
Noah_Katz
No screencast audio because of background noise.
The sketcher seems to have broken in this design; when I try to constrain an unconstrained line it tells me it will be overconstrained.
Then when I tried to revert to the previously saved version, I couldn't.
I tried following the help instructions but when I hover near the folder icon the icon that's supposed to appear doesn't.
Link to design: https://a360.co/3AarKZu
Replies (11)
Message 2 of 12
Phil.E
The design is not downloading for me. Can you possibly attach it here?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 12
jeff_strater
Aslo, I don't see a screencast here.  If you are having problems with inserting it, just share the link here.  Thanks.
Jeff Strater
Engineering Director
Message 4 of 12
Noah_Katz
I tried exporting the design as an .f3z, but it failed after 15 min.
Finally found the darn .f3d after waiting 15 min for search to complete; attached.
The screencast showed in the post preview, not sure why it didn't appear, but the link is https://autode.sk/33v1mgT
I tried to search my computer for the .f3d but only two out of dozens came
Message 5 of 12
TheCADWhisperer
Open your file.
If the component in question is external - make it local.
File>Export your *.f3d file to your local drive and then Attach it here to a Reply?
If the sketch in your screencast is a single sketch - it is far far far too complicated.
Use several small sketches rather than one large sketch.
Most Fillets should be done as placed features rather than in sketch.
Message 6 of 12
Noah_Katz
What component? The problem is in sketch mode.
It's attached to my previous post.
Message 7 of 12
TheCADWhisperer
A sketch can only be created in a Component (either at top level or sub-component).
Message 8 of 12
Noah_Katz
Ah; it's an internal component.
Even if it wasn't, not sure how that could explain the problem suddenly occurring after having edited the sketch hundreds of times before.
Message 9 of 12
TheCADWhisperer
Be careful doing this if you are not sure -
Can you save a copy of the file, delete all of the extraneous stuff and Attach the cleaned up file here? (Only interested in the sketch in problem statement.)
Message 10 of 12
Noah_Katz
OK, attached.
The problem isn't as bad now.
I still couldn't change the rightmost vertical line's dimension to Driving, but it did let me create a new one and dimension it, which I couldn't do before deleting the rest of the design.
Are model files still called designs?
I really dislike that terminology because it creates confusion when you want to refer to a design.
If you're not sure what I'm saying, I rest my case.
Message 11 of 12
TheCADWhisperer
From my experience - this should be at least 3-5 separate sketches.
I would expect to have issues with a sketch like this (in any parametric MCAD software).
Message 12 of 12
Noah_Katz
I know that now but this was one of my first projects and I didn't learn that out until I was deep into it with dozens of parts and joints.
I understand that big sketches kill performance but not why it would make sketching malfunction.
