Imagine this……you’re sketching a shaft. This shaft is 120” long therefore it requires a lot of zooming to see the details and there are many details.
Now you are looking at the sketch all blown and rotated into the desired position and you need to make an edit.
Soooo…… you go to the Browser and click Sketch (the appropriate sketch) then click “Edit Sketch”
The first thing our software does is to zoom completely out on the shaft and rotate it to some undesired position.
Now that “Edit Sketch” is activated the first thing ya have to do to make the desired edits is to “Zoom” to locate the desired detail and then “Rotate” back to the desired position so that you can now Edit the Sketch
Can you tell me if there is setting that will hold the shaft on Position when “Edit Sketch” is activated?
Harry Babb
