Fusion Support
Sketch plane
1 REPLY 1
cwolfe9311
51 Views, 1 Reply
Sketch plane
Screenshot (1).pngWhen i select a plane to sketch on it rotates along the z axis 180 degrees and now im drawing in the x negative y positive. I don't know why it is doing this or how to fix
1 REPLY 1
You can orient as desired on the View Cube upper right corner of your screen.
You might also change this setting in your Preferences...
