Fusion Support
Sketch overconstraining problem - ellipsoidal head
2 REPLIES 2
szabolajos
96 Views, 2 Replies
I am sketching an ellipsoidal head contour according to DIN 28013 to revolve. After having the diameter and the thickness I would like to determine the knuckle and dish radii on the inside contour
which lead to overconstraining.
I thinkn this is a bug, since defining the outside radii works fine.
Cheers,
Lajos
2 REPLIES 2
HughesTooling
in reply to: szabolajos
You are not allowed to drive the source curve off the offset curve. Just a limitation to offsets. Might be easier to revolve a solid then shell.
Mark
Mark Hughes
Owner, Hughes Tooling
szabolajos
in reply to: HughesTooling
Thank you
