Sketch not fully defined.
Fusion really sucks. I am getting annoyed every time I use it. Now my sketch isn´t black. Every time I try to add a dimension it says it is over constrained. I tried adding the file here, but since I have used cad programs since the nineties I am unable to even add the design so that you can look at it. So I have went from being quite skilled to needing someone to hold my hand to draw simple things. Everything also takes 10 times longer in Fusion and I loose valuable time and focus. Also: Why not saving the file locally? I travel a lot and while being on a boat, the countryside or a flight I can forget using my time to work. Autodesk is really just for stationary office people. I already uninstalled Fusion once and promised to never use their softwares again, but here I am, money talks, or rather no money. So: How do I attach the design to this forum from the fluffy cloud? If I drag and drop from Fusion360 the dropbox moves out of the way. A handy way for Autodesk to get rid of users? Edit: Another half an hour and two lines in the sketch is black. A couple more work days and I have managed to make a rectangle with two fillets. Also: Why no snap tools? Why are all of the normal Autocad standard drawing commands removed from the sketch tool?
@jan_murberger - this post has been edited due to Community Rules & Etiquette violation.
