Announcements
Sketch Not Constrained
wmhazzard
wmhazzard
How is this sketch not fully constrained?
HughesTooling
Seems like the vertical 1" dimension is not being seen correctly, it should be fully constrained by this dimension. If you add lines then dimension it does solve as fully constrained.
Mark Hughes
Owner, Hughes Tooling
wmhazzard
It does look that way. I wish they would overhaul the sketching area before implementing new functions every month.
TheCADWhisperer
What is interesting is that if I create construction line center to center on the right the entire sketch becomes constrained.
But if I do the same thing on the left - only the left circle shows as constrained.
