I am creating a standard drawer that I will use to drag into all sorts of different designs. I want to be able to quickly drag it in, position it, and then constrain the sketch to the opening of the cabinet, and then break the link so the drawer is local to the cabinet. It works great, right up until I break the link.
Before I break the link, the sketch is where it should be (if I position it with the "move" command, NOT with the joint command):
As soon as I break the link to the external file so the drawer is local to the design, the sketch reverts back:
The sketch moves over to where it was originally when the drawer was inserted. When I finish editing it, it moves back.
This means I can't relate the sketch properly to the cabinet.
Am I doing something wrong here? Any advice would be appreciated.
Thank you,
Chris
