Fusion Support
Sketch is doesn't show in viewport and looks suppressed in timeline
7 REPLIES 7
Message 1 of 8
Rockks
291 Views, 7 Replies
Hi everyone, I'm encountering an issue with a sketch in Fusion 360. I'm unable to edit it as it appears to be suppressed in the timeline and does not show in the sketch folder. When I click on it, it only displays as a preview, and I'm unable to make any modifications.Sketch-Problem.PNG
Labels (1)
7 REPLIES 7
Message 2 of 8
HughesTooling
in reply to: Rockks
Have you tried a Compute All (Ctrl+B)? Also have you tried closing and restarting Fusion? If those don't work can you share the f3d file here?
Mark Hughes
Owner, Hughes Tooling
Message 3 of 8
TheCADWhisperer
in reply to: Rockks
@Rockks
Are all of your sketches fully defined?
Are all of your sketches 2D on original sketch planes?
Message 4 of 8
Rockks
in reply to: Rockks
@TheCADWhisperer @HughesTooling here the file:
Message 5 of 8
HughesTooling
in reply to: Rockks
By suppressing the sketch before the problem one then unsuppressing, the problem sketch also unsuppressed for some reason!
Mark Hughes
Message 6 of 8
Rockks
in reply to: HughesTooling
@HughesTooling thank you so much for this. Solved!
Message 7 of 8
@jeff_strater Any idea what might of gone on to cause this problem? Is it because the sketch was suppressed and it lost a reference while suppressed?
Mark
Mark Hughes
Message 8 of 8
Not sure, @HughesTooling .  That theory seems pretty reasonable.  I have seen a handful of issues like this in the past, but never have figured out how to reproduce it.  If anyone ever does, we'd appreciate it.
Jeff
Jeff Strater
Engineering Director
