Sketch Invisible in Drawing workspace
crfarmer
crfarmer
I have drawn a 3D model in the design workspace and when i change to drawing workspace, no matter what template i use the style visible and hidden edges and visible edge. how can i change this. I have updated the graphics drivers. How do i fix this problem?
jhackney1972
A model sketch can be made visible by going to the Browser, in the 2D drawing, and turning it on.  Looking at your screen capture, your sketch folder is hidden.  I cannot tell if the sketches in it are off or on.  Sketch lines, in the drawing space, are always, what I call Phantom lines.
John Hackney, Retired
crfarmer
Yes i thought that too i should've had it turned on in the first photo. But no, not the solution.
jhackney1972
You are having graphic card driver issues.  You border and title block are messed up and broken.  There have been numerous forum posts lately where the drawing workspace is not displaying correctly and they had to update their graphic drivers to get it to clear up, especially if you have a Radeon Graphic card.
crfarmer
I have updated the graphics driver to the latest release. restarted computer and fusion. Still encountering the same problem.
ClintBrown3D
Hi @crfarmer
This issue is caused by a recent Windows update that has rolled back certain Graphics drivers, it appears that AMD cards are most affected. The good news is that most of the reported cases have been resolved by updating the graphics driver.
If you update your graphics driver directly from the manufacturer's website (NOT via Windows update), it should resolve the issue. Fusion has a built-in tool that will identify your graphics card, see below. Clicking on "Check for GPU driver update" will take you to the manufacturers' website. From here you can find and install the correct driver.
If you are still having issues, please see this article for more help
https://clintbrown.co.uk/updating-graphics-setting-for-fusion-360-customers-experiencing-fuzzy-or-mi...
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
ClintBrown3D
Hey @crfarmer
Just checking in, did you see my reply to your post? Have you managed to update your graphics driver?
Clint Brown
