Announcements
sketch inversion
accountsEFWLY
sketch inversion
accountsEFWLY
I run into this often, when modifying a sketch dimension or moving a part of the sketch will cause an inversion or a flip of sketch elements.  I'm never able to figure out how to fix this, instead I always end up deleting sketch elements and starting over.  This is very time consuming and annoying when something is changed in a sketch, and subsequent things downstream are broken, and with the deleted/recreated elements I then have to go through the deleting the yellow broken links and relinking rigmarole.
For example, below I moved something slightly and the highlighted arc flipped 180 degrees:
Is there a way to flip these elements back?
Thanks.
bharamk
Hello @accountsEFWLY
Sorry to hear that your facing issues. could you please attached dataset and steps to reproduce here?
Thanks & Regards,
Ketan Bharamgunde
Sr.SW Eng.Test
Autodesk, Inc.
