Sketch Fillet Bug Report
nnikbin
nnikbin
After running sketch fillet command, it prompts to select the first and second "line or arc". In practice it does not accept conic curves (which, of course, does not contradict the prompt) but it accepts fit point splines. Sometimes it throws exception which kills Fusion 360 process when fit point splines are used as input. It seems producing fatal error is dependent on the fillet radius and the angle between fit point splines (or fit point spline and other curves or lines). Please view the following screencast:
https://knowledge.autodesk.com/community/screencast/2c14607e-1477-4158-812a-ab115b2db248
rohit.bapat
Hello @nnikbin
Thank you for reporting the problem. I was able to reproduce the crash thanks to the precise screencast video. I have logged a ticket for the development team to look at.
Thank you,
Best Regards
Rohit Bapat
Rohit Bapat
Product Owner
nnikbin
Thank you @rohit.bapat  for reproducing the crash and reporting the bug to the development team.
