Sketch Equal Constraint Issues
- Mute
- Permalink
- Report
When sketching and setting Equal constraints between two lines everything works fine in most cases. When I dimension one the second instance tends to flip direction or disappear. This means I have to dimension before placing an equal constraint so it won't flip out. To compound the issue more the response isn't consistent. Some cases it will let me change the dimension and work, and others i will use the same dimension on the same sketch entity and it won't.
Example images.
1. Draw the vertical lines, dimension 5mm and then add an equal constraint. - works fine.
2. Change the dimension to 4mm and the sketch flips out
3. On the "flipped out" sketch change it from 4mm to 6mm and it fixes itself
4. Undo back to the original 5mm and change it to 6mm and it flips out....(won't let me upload 4 but looks just like 2)
