I have a parametric design with a rotating pattern. Inside the rotating pattern is a spline. The problem is that the spline does not update properly when the parameters are changed. If I open the "Edit Circular Pattern" and close it again it updates properly.
In the picture the top inner spline is the correct one, the rest five have not been updated.
I can share the design if someone want to inspect it.
