I am getting back into some CNC programming after many years. I imported (using copy and paste) a drawing I made with an old version of autocad and was very meticulous about aligning it with the origin before I started creating the solid model. Everything seemed to look OK as I was creating the features and bodies. I noticed when I went to the manufacturing page that the origin of the project was no longer aligned with the sketch and bodies. This is the second time it has happened with a different drawing. I have attached a picture which indicates it is offset by .059 and .03.
I can move the sketch over to the project origin but the body really gets out of whack apparently because some of the components I created were not on the sketch. The pockets in 3 of the spokes don't move. Why is this happening? I haven't gotten into the machining yet but when I attempt to drill the center hole the gcode needs to move to X.0 and Y.0
