Fusion Support
Size / scale issues.
11 REPLIES 11
Message 1 of 12
mpinchot
216 Views, 11 Replies
When drawing a simple part, my sketch shows a 6" pipe. The drawing is in inches and the sketch shows 6". This printed at a little over 3". I went back in and used the "inspect" tool for "measure" on my sketch and the diameter only showed at 3" when inspected, but my sketch and drawing show the correct desired dimension as 6" .
Not sure why my drawings are correct but they do not "measure" or print as drawn.
Any help is greatly appreciated.
11 REPLIES 11
Message 2 of 12
jhackney1972
in reply to: mpinchot
How are you printing?  Is this a 2D Drawing Print or something else, please clarify.  Maybe a few screen captures.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Message 3 of 12
g-andresen
please show your measurements in a screencast and share the file
File > Export > save as f3d on local drive > attach to post
günther
Message 4 of 12
mpinchot
in reply to: jhackney1972
Here are 2 screen shots...
1 of my sketch as drawn with a 3" radius pipe, and the second showing the dimension as 1.375 when measured using the inspect tool.
The issue came to light when I 3d printed from the stl file and the part was much smaller than desired.
I drew the part as a 3" radius pipe, and it inspects and 3d prints as 1.375 radius.
Message 5 of 12
g-andresen
From your words and the screenshots you can not make any conclusions.
Please share the file.
günther
Message 6 of 12
mpinchot
in reply to: g-andresen
https://a360.co/3L8SmAE
Here is the link.
Message 7 of 12
g-andresen
The link has no download allowance.
If you use a personal license you have to choose the way described above (#3).
günther
Message 8 of 12
ryan.bales
@mpinchot since i have the support case i figured i'd chime in here too.
I think from what i can tell your sketch is showing the diameter of the pipe is 3". We can never know how you drew a sketch as they contain no history so this is very difficult to prove it was ever anything but 3"
Ryan Bales
Fusion 360 Product Support
Message 9 of 12
mpinchot
Here is the download per #3.
Message 10 of 12
mpinchot
in reply to: ryan.bales
Ryan,
It is the radius that was drawn as 3" ... That is the issue. Not the diameter
Message 11 of 12
mpinchot
Ryan, and G-andresen,
Thank you for the help...
I will re-draw, I am guessing that the diameter was plotted in lieu of the radius.. will try again, thank you for your responses.
Message 12 of 12
ryan.bales
That sounds like the only conclusion i can draw. Every other dimension is related to the OD of the pipe being 3". I'll respond via the case email as well.
Ryan Bales
