Announcements
size bug using tools make then 3d print
matt105BF7A
Observer Observer
matt105BF7A
Observer
Observer
i mainly use fusion with inches but this project i used mm
then i sent the file to cura 4.9.1 the modal was supposed to be 120 mm (Length) x 120mm (width) by 17.907mm (height)
but what i got was 4.7244mm x 4.7244mm x 0.705 witch are oddly the inch measurements but imported as mm
wassi3
STL and OBJ are 'unitless' formats
The export does a number conversion based on the unit you select for STL or OBJ
Cura interprets them always as mm, no matter what you tell them in the export
Use 3MF to avoid these issues and preserve your intend
HughesTooling
Had you sent any other meshes to your printer that day that were in Inches? Fusion automatically scales meshes to MM when you export directly to your slicer but there's a bug that means if you use 2 different units of measurement in a session Fusion gets confused and does the wrong scale.
Try closing Fusion, restart then open your MM design and export again and see if it's correct.
Mark
Mark Hughes
Owner, Hughes Tooling
matt105BF7A
Observer
Observer
the issue was fusion was sending it over as inches i have to manually select mm  and the format is locked to (stl binary) this is the first time i had to adjust settings in the 3d print menu
HughesTooling
Are you using the custom option to send to your printer? If you are Fusion should export to mm automatically no matter what units the document is in. But it doesn't work well and gets confused if you sent one design done in inches then send one in mm.
Mark Hughes
matt105BF7A
Observer
Observer
 this is what i get when i open the print menu
it will work correctly if i manually select mm every time but i haven't  had to do this with pervious prints
