Fusion Support
simulation ring at centrifugal force
4 REPLIES 4
bayer_o
191 Views, 4 Replies
I want to simulate a ring (Ø100 x Ø90 x 20) rotating around his axis.
I  have a problem to find the correct constraints because the ring is axially not fixed.
I will compare the result with an analytical solution. If it fits together then I will change the geometry to a more complicated one.
What is the right configuration of the constraints?
Thank you
4 REPLIES 4
TheCADWhisperer
in reply to: bayer_o
@bayer_o
bayer_o
Thank you,
the result in radial direction is ok.
The displacement in axial direction is 0 on the inner surface, which is fixed by the constraint.
How can I avoid this?
TheCADWhisperer
Simplify to quadrant of the geometry.
This permits placement of Frictionless constraints on cut faces.
Checkmark - Remove rigid body modes...
Edit: I would probably increase the Mesh density too.
Edit 2:  Never mind - I was thinking pressure, not centrifugal force.  My mistake.
bayer_o
in reply to: TheCADWhisperer
Thank you,
I foolwed your suggestion, but the result is not correct.
Technology Administrators
