Announcements
Simulation: Regularisation error
I am trying to run a simulation but the simulation failed due to a regularisation error. I’m not sure what this means and I was hoping someone could help. I have attached the part below. Thank you.
jhackney1972
I do not receive any error while running your simulation.  I am doing it locally.  The only suggestion from the simualtion is that your part is over designed for the safety factor.  If you receive this error again it usually is because there is modeling error, overlapping bodies or other problem.  Model is attached with the completed simulation.
John Hackney, Retired
Thank you so much.
