Simulation components lose visibility permanently when toggled with "V"
Hello!
I have a problem with a model simulation.
Simulation components lose visibility permanently when toggled with "V".
Toggling visibility from browser works normally, but toggling visibility by pressing "V" makes visibility gone forever. Restarting Fusion, going to other workspaces or simplify and coming back etc. doesn't help.
In Simplify all components are showing. In design workspace they are all showing too. When creating a new simulation model, all components are visible, but this same issue can be repeated again.
As a side note: The model has been mostly created using the API. For some reason the "Timber" components created from API have always been transparent no matter what i have tried from API or UI. Actually the components are not transparent, but it seems that the faces are inside out. You can see the bodies opposite faces, but not through the body. This might have something to do with this issue. This would be nice to get solved too.
Best Regards,
Ilkka
