09:28 AM
Question from a newbie.
I want to fill the side of a wooden box with wood boards so I use Rectangular Pattern.
The amount of wood boards is calculated, depending on a Height parameter of the box, and a Width parameter of a single wood board.
Now I want to cut the top board.
I use the tool "modify" -> "split body" by using a plane.
The result is that every board is cut, which is not desirable of course.
Can you advice me on how to do this correctly?
Roeland
