Signal Integrity Extension CVS File Data
(x-post from Electronics)
Is there a document for the Signal Integrity Extension that explains the data in the exported CVS file? What are the paths and segments and how are they defined? Also, why is the CVS data in a non-number format having a text unit after each number? This text must be stripped out before analyzing the numbers in a spreadsheet. The numbers themselves are repeated in each column in groups of segment and path totals, making it impossible to simply sum columns of numbers. And speaking of sums, the trace length sums (in mils) are much longer than the trace lengths (in mm) in the CVS file exported by the Eagle ULP data export script.
Gary
